Hi .
I’ve got a fully off the grid set up where inverter ( first point of entry ) got the ground and neutral bonded .
I then distribute to the house via a disconnect on the exterior wall .
Since I know that only the inverter should be bonded , where do I place my ground on such a disconnect ? ( which have a ground connection on the neutral bar ) , or do I just connect it with a nut directly to the house panel ground bar ?
Thank you very much .
