Hello,
I have a small cabinet with just a 120 VAC to 24vdc siemens power supply in it. It supplies 24vdc to a nearby cabinet.
Does this small enclosure require a disconnect switch something similar to the 480 vac disconnects?
However, I am planning to use a circuit breaker inside the same enclosure where the 120vac connects first before it is wired to the power supply. Will the circuit breaker enough?
Or do I need a Rotary disconnect on the door or so
