Energy-Miser
- Maryland
Gave an estimate for a new hot tub, with existing underground wires piped right to the side of the hot tub (this is a new but replacement hot tub). The wires are adequate, breaker the right size, etc. three pipes coming out of the side of the house. Home owner assured me that the pipe on the left was the one for hot tub, I saw there was enough room to the left of this pipe to put the disconnec right next to the condulet. At install time found out the middle pipe was the one for the hot tub and not the left most pipe. There is no room around or above this middle pipe for the disocnnect. Is there a way to put the disconnect (it is a 60 amp GFI disconnect made for hot tubs) near the hot tub where the wires come out of the gournd, and remain code compliant? Our other alternative would be to trench out and away from the tub, put the isconnect on a post, and come back to the tub. It will be much more time consuming and won't look very nice. Home owner from the beginning tried to encourage us to put the disconnect at the hot tub. Any hope for saving this mini project?? e/m
