Trouble shooting a lighting and receptacle circuit in a residence. Wiring neutral of one circuit to ground for return path from one end and gas furnace circuit hot from the other end ?? Long story short:
Question. Does the circuit breaker for the gas furnace in a panel in sight and 20 feet away satisfy requirements for the maintenance disconnect switch or do I need to install a switch on the unit itself?
Thank you
Thank you
