Streetsahead
- Vancouver, WA
Hello all. I'm a new journeyman after a four year apprenticeship, so I've still got plenty to learn. I've searched but haven't found anything quite like this. I've called local code enforcement but while I'm waiting for a reply I'd like to see what you all think.
What I have is a detached garage(4 ft between it and the home), for now we will assume(I haven't seen it yet) it is being powered with a uf circuit or two, so no feeder in the garage or conduit connecting, becuase the Solar contractor is quite sure we will need to use EMT between buildings. They are installing enphase panels, with built in inverters. Straight from the panels it sends 240v AC not DC out, and back feeds a 20a two-pole in the panel.
So
1) I've found nothing that states I can't run 4 feet of EMT between home and detached garage. Can someone verify?
2) I assume they will want to see a disconnect on the garage. Any reason a 2p 30a disconnect wouldn't work in this application?
3) On the previous install of this type (panels were on house roof so no detached business) the inpector let me use an irreversable crimp to connect my #6 ground from the panels/collector to the GEC in the panel going to my ground rods. Will I need new ground rods for my #6 since it's so far from the house?
So
