Sean.Day72
- Florida
I've seen some debate on here.
Replacing a bunch of roof top exhaust fan that are about 20 years old. None have existing disconnects on the roof within line of site of the fan.
Some GE combo disconnect Motor Starters in the mechanical room below some I couldn't not locate a disconnect/motor starter. It looks like they are fed directly from a breaker?
I guess the first question, from Article 430 it appears these are required within line of site UNLESS there is a disconnect that can be locked in the open position. I believe we meet this exception.
If we are to add a local disconnect what is the best way to go about doing this. The exhaust fan are mounted on top of a roof curb with the conduit coming up right in through the bottom. We would have to cut a hole through fan shroud, length of flex, weatherproof hub, and mount the disconnect to the side of the fan. I don't really want to field modify a fan to install a disconnect..Thinking of use a smaller Nema 3R rotary type motor disconnect. Most are 2 HP motors.
