Andres Arias
PV Solar engineer
- New York
- Electrical Engineer
During the installation of residential photovoltaic PV systems in New York City, we used to install a disconnect between the AC subpanel (that controls the strings of the solar modules installed on the roof) and the electrical main panel of the house. As a thumb rule, we always proceed with installing that disconnect at no more than 10 feet from the electrical main panel, either inside or outside of the building (house). However I would like to know if the 10 feet rule is clearly stated in a any electrical code in NYC, as checking in NEC the 10 feet is not stated in the 690.13; just saying that the disconnecting means should be readily accesible.
Thank you
Thank you
