wrobotronic
- Colorado
Hi all,
Is a disconnect for a separate garage required for two circuits? The garage in question just ran two uf cables and then branched off of those two to supply the garage. Is a disconnect required? ie can a normal single pole switch be used if marked as a service disconnect? And if so could you direct me to the code section that I can use?
Thank you all very much.
Wrobo
Sent from my SM-G900V using Tapatalk
Wrobo
