I want to install a 3 ph motor (32.2 amp 208 VAC) located in a Class I Divison 1 area. It's feeder will come from a control panel that will be in a different (unclassified) area and will be protected by 50 amp fuses.
Can I use a Class I Div 1 rated switch (120 VAC) located next to the motor in the Class I Div 1 room to operate the coil of a contactor (rated 50 amps) located in the control panel to disconnect power to the motor?
Would this arrangement be a permitted option instead of installing a 50 amp 3 ph Class I Div 1 disconnect in the room next to the motor?
I'm looking at Artical 501.6 for info but this situation doesn't appear to be addressed. What other code section deals with this issue?
