jonmathison
New member
An emergency generator enters a building through a disconnect switch rated at 300 Amps. Technicians have measured a base load of 30 Amps with spikes to 271 Amps at this disconnect switch (the spiking is due to two 30 HP elevator motors). Does the NEC impose an 80% safety factor on disconnect switches serving as the entrance point to an emergency generator (i.e. the switch should not be subject to more than 240 Amps)? I know this is good design practice but haven't been able to locate it in the code. Thank you.
