Disconnect switch behind a door
mshields
Boston, MA
I have a kitchen in which there is a 100A-3P disconnect behind a door. The inspector is making us move it. I get the rational (i.e. that some could open the door while you're working on it. But is this, strictly speaking, a code violation per se?
thanks,
Mike
eprice
Utah
mshields said:
...But is this, strictly speaking, a code violation per se?
No, unless the inspector is aware of a code section that I'm not aware of. Ask him for the code reference and let me know what it is so I'll know better next time :)
P
Physis 3
Guest
Usually there isn't a problem if you can open the door and the panel clearances are met. Sometimes an inspector will gripe about it. I can't check the code right now but I think as long as the door opens your inspector just has to learn how to do that.
As far as an inspector "making" you do something that isn't code based, well, that's actually your choise.
augie47
Tennessee
the bright side
the bright side
as has been pointed-out here previously...
it's the one place in the building that won't have "stuff" stacked in front of the switch.:smile:
infinity
New Jersey
Journeyman Electrician
We install panels behind bedroom doors in apartments. Actually a good place for them given the potential storage issue.
boater bill
Cape Coral, Fl.
If we couldn't put panel behind doors, there would be a huge amount of homeowners and apartment residents that would have to hang a picture over the electrical panel instead of opening a door.
I design behind a door every chance I get to keep the area in front of it clear.
I would be asking for specific code references.
SmithBuilt
Foothills of NC
I think the OP is referring to a disconnect that must remain in the line of sight of the equipment being worked on. Not so much a panel being behind a door.
Is the disco in the same room as the equipment?
P
Physis 3
Guest
Wouldn't it be easier to lock the door than move the disconnect?
