Hello All:
I'm working on a project where a 1/2HP, 208V/1PH pump is located outside a data center facility in a manhole. The controller with integral disconnect is located in enclosed mechanical yard by the entry door which make the disconnect not within sight of the motor. If the disconnect or the upstream breaker in the panelboard is lockable in the open position, would still require us to provide a disconnect within sight of the pump? Any thoughts?
Thanks,
Thanks,
