Typically industrial panel disconnect switches are mounted near the top of the enclosure. The Line feeds the fuses from the top and the Load is connected to the bottom.
I have a rotary shaft operated, fused disconnect switch that I want rotate 180 degrees so that the Line feeds in from the bottom and the Load connects to the top. The disconnect switch will be mounted near the bottom of the panel so it will have a bottom feed to the enclosure.
I know this isn't the conventional mounting arrangement but are there any rules that say you can't mount the disconnect switch in this manner?
