Hello,
I have a 30A/3P/fusible disconnect switch installed in an elevator machine room for the cab lighting (120V, 15A) which was installed based on an engineers' sketch with a mistakenly copied note. Can this switch be wired with hot/neutral/ground and still pass an inspection? I wasn't sure if wiring it this way goes against the manufacturer's intended use for the switch (I know that's in the code somewhere...).
After this issue came to surface, the engineers required a 20A/1P enclosed circuit breaker to replace it, but since it is not lockable, it is not allowed to be used in the elevator machine room.
Thanks!
Thanks!
