Vickie
- United States
According to NEC does the disconnect switch have to be red/yellow if there is a red/yellow kill switch installed? Machine design.
A kill switch (emergency stop) is not a disconnect. Many types of equipment will require both emergency stops and disconnect switches. Emergency stops are not required by the rules found in the NEC. Disconnect switches are required by the rules found in the NEC.According to NEC does the disconnect switch have to be red/yellow if there is a red/yellow kill switch installed? Machine design.
What does "IMO" signify?
NFPA 79 covers that the emergency stop devices must be Red/Yellow, code 13.2. All disconnect switches that we currently receive are red/yellow however for overseas and using EN directives they state that if the main switch is not used as a "kill switch" then it must be black/grey. I am just trying to simplify stock and use one color.
