FOR YEARS, I'VE WORKED WITH PEOPLE FOLLOWING A "36" RULE FOR MOUNTING A NON-FUSED DISCONNECT IN LINE BETWEEN THE WEATHER HEAD AND A PUMP CONTROL. IN OTHER WORDS, IF YOU USE A NON-FUSED DISCONNECT, IT CAN BE NO FURTHER THAN 36" FROM THE CONTROL (WHICH CONTAINS AN MCP). I'VE BEEN DIRECTED (VERBALLY) THAT ANY DISCONNECT THAT EXCEEDS 36" MUST BE FUSED. WHAT SECTION OF THE CODE CAN I LOCATE THIS INFORMATION? I'M STRUGGLING TO FIND THIS. IN MY MIND, THIS WOULD BE CONSIDERED A BRANCH CIRCUIT...CORRECT? THANKS MUCH!
