Hello. There is an existing commercial building that is being fed from a pole mounted transformer. The overhead cabling is going directly over the building with a weather head and vertically penetrates from the roof to the main panel location with a 600AMP main breaker. The meter is on the outside of the building with wiring from the CT on the weather head i believe. I believe that is NEC compliant. Since it has a main breaker disconnect at the panel it enters overhead. Is that correct?
In my area i typically see weatherhead to the meter location with a disconnect (exterior) and then it goes inside to a interior panel. Or underground to the meter or even underground to main panel inside with a disconnect. First seeing it directly going inside to building in my area. See attached picture.
thank you
thank you
