bcorps
- Evansville, IN
- Engineer
I have a quite crowded Mechanical yard with 32 condensing units. The yard is just outside the main Electrical Room. The condensing unit spacing is too tight for disconnect switches at each unit (only 31 inches between rows). I considered ganging four switches at both ends of each row (units are in a 4 x 8 configuration) to satisfy the "line of sight" rule, but I am wondering if I can just feed them from panels just inside the Electrical room. If I put "lockable in off position" accessories on each circuit breaker, will this give me the "line of sight" exemption I need?
Also, the way I read the code, getting around the line of sight issue doesn't get rid of the "within 50 feet" rule. Correct?
P.S. I did consider putting the panel outside with the condensing units, but they are almost 7 feet tall, which would prevent line of sight anyway, so that's why I'm considering keeping the panel inside.
