J
jonny1982
Guest
I have heard a lot of different opinions on disconnects. What is the rule on them? If the panel is in site, a certain amount of feet away, etc., are they not needed? Our they only needed on equipment with motors? If equipment is over a certain amount of amps, are they needed? Are they needed to be a certain amount of feet away from equipment they are servicing, or just in site? If the equipment has a disconnect built into, is another needed?
If a chiller has a disconnect inside of it built into control panel, is another needed on the outside of it to be able to shut it down without opening it up?
Thanks.
Thanks.
