wireman1
disconnects which service garage doors in a service center be cabable of be turned off without the use of a ladder or lift ?the disconnects are about 15 ft from the finished floor they may be fused .the circuit breakers which service these disconnects are located in a electrical room which is in a different location and out of sight . the article I used was 430 .107 and readily accessible .I think this situation because they state one of the disconnecting means must be readily accessible .being that the circuit breakers are in a different location it does not meet the requirments of the code. I think if you used 404.8 exception 3 this would be code compliant need some comments please thanks
