Morewires1
New member
Have a commercial 18" Dish install on exterior wall, 12' above grade. For cable protection, want to run all conductors in pipe and an LB to enter building. Probably use 1" pvc. Question: My #10 dish ground and (4) coaxes- can they be run inside the pipe, enter the building and be grounded from there? The #10 from the dish would come to a bus bar, and the bus bar would continue to the building ground with #10. 4 Coaxes would be thru grounding blocks, grounded to the aforementioned bus bar. The bus bar would be within 2' of the entry into the building, and the #10 to the building ground is about 20'. Looking to know if i can include my #10 in the (pvc) pipe, and if I can use the bus bar on the inside of the wall. thanks in advance!
