sourcream22
- New York
What is the proper way to install a corded dishwasher?
I read in the code that the receptical must be accessible. I have read a rather long thread on this forum with people arguing about if the outlet can be behind the dishwasher or if it must be behind the sink. If the dishwasher slides out easily and drain/water hoses and electrical cord are long enough to move the unit out into the kitchen two feet away from its enclosure can the outlet be located behind the dishwasher, i.e. is it considered accessible?. The dishwasher has its own 20 amp GFIC outlet connected to its own breaker via 12 gauge wire. I know GFIC is not necessary when it is under the kitchen sink but I read it will ensure the "graceful failure" of a dishwasher if it does fail.
People cited a possible cause of concern to be vibration causing the plug to become lose. However if it is connected to a GFIC it should be alright? I don't see the dishwasher vibrating much anyway... it's not a washing machine..
I am in westchester county by the way. It seems that people are saying different things about this issue.
Thank you.
Thank you.
