junkhound
- Renton, WA
- EE, power electronics specialty
Asking here as someone may know hot tub details.
GD filled with hot water from gas WH and tripped the bimetal disk protection t-stat. I was able to reset OK, etc.
However, the Genesee Hot SPrings hot tub has a small 3/8 dia vinyl tube connecting the overtemp control box and 'somethng'
It has hardened with age and proke off the nipple to the contorl box. Sealed bothends with wooden dowel plug and silicone, after resetting the overtem tstat hot tub heats, draws 21.4A, etc. etc.
What I dont know or can find out on the internet is what that hose does or controls. No observed differnece in operation with it plugged. When broken, both ends squirted water at just gravity pressure.
Annehave any idea what that controls? The end at the overtemp tstat connects to the water flow thru the heater, no idea where the other end goes, it dissapears nto the tub insulation.
