petersonra
- Northern illinois
- Semi-retired engineer
from another post
Would a 2 pole relay actuated by an estop PB be an "approved" method?
Would a 2 pole circuit breaker located in a closed cabinet be considered "readily accessible"?
514.11 Circuit Disconnects.
(A) General. Each circuit leading to or through dispensing equipment, including all associated power, communications, data, and video circuits, and equipment for remote pumping systems, shall be provided with a clearly identified and readily accessible switch or other approved means, located remote from the dispensing devices, to disconnect simultaneously from the source of supply, all conductors of the circuits, including the grounded conductor, if any.
