There's an exsiting 3-section switchboard, consisting of a 1600A main fusible switch, and two 1600A feeder distribution sections on the same lineup. The main is fed from a 1600A fusible disconnect switch from a separate distribution switchboard. I am planning on removing and replacing the 1600A main fusible switch section with a new 2000A rated MLO section and keeping the two existing 1600A distribution sections. The 1600A feeder switch will be replaced with a 2000A rated switch and associated feeder conductors. Out of the new 2000A section, I will install a new 1200A feeder breaker to sub-feed a new 1200A rated distribution board. Does this arrangement comply with code?
