I have 02 DG Sets of dissimilar makes, with each DG set having three-pole ACB and switched-neutrals (as DG output breakers) and connecting their outputs on a common TPN Bus-bar.
Due to some unwarranted conditions, the DGs paralleling and synchronization is not desired. I wish to run both the DGs as standalone DGs, in both the cases using the common output bus-bar to which multiple loads are connected. Under such scenario, I need to electrically and mechanically interlock both the DGs output ACBs. Since, the neutrals of both the DG sets are switched through dedicated relay, mechanically interlock is not possible for neutral line.
I wish to know, would the electrical interlocking only for the both neutral lines be a safer approach.
(a) If no, why?
(b) If yes, how?
(c) Is it essential to use 4-pole ACB for both DG set?
Appreciate, your responses.
(a) If no, why?
(b) If yes, how?
