Re: distance between boxes
Hurk27, you are absolutely right, if we were running 4, 600kcmils the max pulling force would work out like this.
Area of the wire is 600,000cmil
Allowable stress on soft drawn copper is .008 pounds per cmil
Number of conductors is 4
A constant for more then 3 conductors is .8
600,000 x .008 x 4 x .8 = 15,360 lbs of pulling force allowed, however southwire recommends not to exceed 10,000lbs and 90% of our sheaves are rated 10,000lbs so we try not to exceed this.
Our largest Greenlee tugers are rated 8000lbs continuous or 10,000lbs intermittent, it is faster and easer to use a large all terrain scissor lift, it has the power and steady slow speed you want.
Here is a link to more info on this.
Southwire Technical Paper
