Re: distance between raceways in the code
314.28
"(2) Angle or U Pulls. Where splices or where angle or U pulls are made, the distance between each raceway entry inside the box and the opposite wall of the box shall not be
less than six times the metric designator (trade size) of the largest raceway in a row. This distance shall be increased for additional entries by the amount of the sum of the diameters
of all other raceway entries in the same row on the same wall of the box. Each row shall be calculated individually, and the single row that provides the maximum distance shall be used.
Exception: Where a raceway or cable entry is in the wall of a box or conduit body opposite a removable cover, the distance from that wall to the cover shall be permitted to comply with the distance required for one wire per terminal in Table 312.6(A). The distance between raceway entries enclosing the same conductor shall not be less than six times the metric designator (trade size) of the larger raceway. When transposing cable size into raceway size in 314.28(A)(1) and (A)(2), the minimum metric designator
(trade size) raceway required for the number and size of conductors in the cable shall be used.
310.15(B)(2)(b) More Than One Conduit, Tube, or Raceway. Spacing between conduits, tubing, or raceways shall be maintained.
SPACING SHALL BE MAINTAINED.
There is no measurement given. Generally the support device (strap) will determine the spacing.
Ask the inspector to reread 314.28 and remind him that is for sizing the enclosure, not the conduit spacing.
