distance from pool wall
giobstii
New member
When running the power supply from the breaker box in the house to the pump, pool light, etc., is there a minimum distance the conduit containing these wires has to be from the walls of an in ground pool?
This can be found in Article 680 of the NEC of which I don't possess at this time.
tom baker
Bremerton, Washington
Master Electrician
Re: distance from pool wall
Are you wiring a pool? If you are, and don't have a copy of 680, you may be in over your head, so to speak. Pools have very specific requirements for safety of the user. Do your self and family a favor, find a local qualified electrican, this site is not for DIY'ers.
G
Guest
Guest
You have gotten off to a rocky start. If the pool light is 120-volts then it is zero feet from the pool walls.
There is very specific wiring requirements for pools. Mixing electricity and water must be done with surgical precision and with extreme caution.
There are different rules for the pool wiring, and there are different rules for non-pool wiring that is in proximity to the pool.
Your concerns will address:
</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Pool wiring</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Non-pool wiring</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Overhead clearances</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Bonding</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Grounding</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Underwater wet-niche lighting</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">GFCI protection</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Conductor sizing</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Junction box type, materials, and location</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Brass vs. RMC vs. IMC vs LFNMC vs. PVC, etc.</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Segregation</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Insulated vs. bare</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Solid vs. stranded</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Receptacle type, protection, and location</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Lighting type, protection, and clearances</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">A rafter of different distances</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Indoors vs. outdoors</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Covered vs. uncovered</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Voltage potential</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Electrocution</font>
  • <font size="2" face="Verdana, Helvetica, sans-serif">Etc.</font>
The Etc. is the deadly part. Pool electrical is a specialty within itself. There are electrical potentials even if no equipment is near the pool.
Proceed with caution. Hire an expert. Don't take the low bid. Pool electrical is serious business. Read up on 680, and then hire the best.
[ September 14, 2003, 05:48 PM: Message edited by: awwt ]
