albator
- Santa Cruz, California
I am putting a sub panel in a detached structure. There's already 3 #8 wires going there (2 hot, 1 neutral, no ground). Customer is on a budget, so they would prefer I don't replace the existing wires right now. Probably in 2-3 years from now they will want to upgrade the amperage.
Under which distance am I required to have a unique ground-neutral connection at the main panel/meter?
i.e. have a ground wire from the main panel in the house to the sub-panel.
Above which distance am I required to have a local ground, and tie ground-neutral at the sub-panel?
i.e. stick a rod at the shed.
Does this distance depends on the wire size and average load? Voltage drop?
