Distance to be maintained between >600 V power cables and low volt instrument cable
I would be obliged if one can help me to decide on the minimum distance required to be maintained between
(1) Power cables (unarmoured, PVC insulated, for 110 V AC, 60 Hz)
(2) Instrument cables (24 V DC 4-20 mA signals unarmoured, PVC insulated, multi core, screened (individual & overall))
I intend to lay the above cables in a covered cable duct (Galvanised steel material) with a space of 150 mm between the power cable section & instrument section. Each of section is only 50% filled.
Do help.
thanks a lot for all your help in advance !
Life's aim is from :-? :-? to :smile: :smile:
Do help.
