MICHAELGALLANT
- Montreal Quebec Canada
I was working on a drive application with 2 evaporators that have 2 motors each coming from the same feeder. All 7.5 hp at 600vac on the same drive, 750 foot runs... I know the voltage spikes can be up to 2400v and I am concerned that the existing cables will cause the motor insulation to burn out quickly. I was looking at sine wave filters but I dont believe it will address the cable insulation & motor insulation degrading quickly. I know VFD shielded cables are a good bet but I was told that the existing cables would not be changed. I believe the motors and cables will fail quickly, even using sine filters. I wanted to know how to calculate the insulation degrading factor on the total 3000ft distance of the 750 foot runs in order to show a comparison VFD cables to standard cables to reduce damage to cables and motors.
