121220-0830 EST
arnettda:
John120's suggestion is good.
Why a 385 A load in a home? Of what does this load consist? I am going to guess resistive heating, resistive hot water tank, maybe one or more instant-on water heaters, hot-tubs, and electric cooking stuff.
I would think the type of loads and their physical locations would a major factor in determining how the loads were distributed. How big is this house? 4000, 8000, 12000, or 20000 sq-ft?
In my own home I have a 200 A main panel in the basement, a basement sub-panel, a first floor sub in the pantry, another in the laundry room, a second floor sub, and a garage sub. I also ran a single circuit from the main panel to an outlet near each sub-panel, and this circuit also supplies the power for several low voltage power supplies for my GE RR relays. These panel locations are for convenience, and the load distribution is what it is. The biggest loads all come from the main panel. The most used breakers for on-off purposes are the garbage disposal, and two circuits in the garage for plug-in heaters. When the garbage disposal needs a hand in the disposal both the wall switch and the breaker are turned off. Having a panel in the pantry makes this convenient.
