Greetings all,
I work in a panel shop and we had an electrician install a 3 phase dist. Block inside a piece of panduit in order to make it 'finger safe'.
I'm told it's to code, but I have been taught never to have connection points inside of a panel's duct. Which this seems to violate. I've also never heard of components being placed inside a panel's duct before. It's still got panduit for the wires all around it. Just a big 6in wide peice of duct that the din rail is screwed to.
I've been searching for documentation in nec or ul 508a that says wire connections inside of panel duct are not to code. But haven't found anything conclusive.
If someone could point me in the right direction, that says whether this is or isn't right, that would be great.
