Grouch
- New York, NY
I understand that when you have a disconnect switch, you have to combine it with integral fuses in order to achieve a short circuit rating (series rated) for the combined device (switch plus fuses).
When you have a distribution board comprised of multiple fusible switches, with a main switch, does each switch have a different short circuit rating depending on which class fuses are installed inside each switch? I would imagine yes. And then the board itself (the copper bus) has its own SCCR rating.
