mbrooke
Batteries Included
- United States
- Technician
Can properly selected and placed MOVs prevent trip and reclose for lightning strikes? What about blowing latteral fuses?
The goal here is to knock down any strikes or switching surges below the BIL. It does not and should not stop a trip because at this point we are conducting ALL current straight to ground including the intended phase voltage. So you should expect a trip.
This- is the best I've seen to date and should be a sticky.
One question- well two anyway:
Since we are dealing with an MOV instead of a spark gap, wouldn't the MOV stop conducting after the over voltage is taken to ground? And as such no trip and re-close will take place?
Second- I've heard of MOVs being able to actually stop trip and recloses on medium and high voltage circuits during a direct lighting hit on the shield wire.
Can Spacer cable take a direct hit? What type of damage does a direct hit cause on distribution system?
Any idea why is the minimum size lateral fuse that can survive MOV conduction during a nearby hit?
As I said a rare strike took out a 230 kv transmission line pole in North Carolina during hurricane Irene about 5 or 6 years ago.
Too many variables to suggest any fuse will survive. It’s all a probability thing.
