Tip DS
I'm here.
- The Great Meme State
- Electrical Engineer
I'm trying to find a way to make the term "diversity factor" a little less ambiguous. Does anyone have a source that clearly defines the term and clearly identifies how it can be determined?
In IEC 60204-1, it requires the following:
5.3 Supply disconnecting (isolating) device
5.3.3 Requirements
Where the supply disconnecting device is one of the types specified in 5.3.2 a) to d) it shall fulfil all of the following requirements:
-have a breaking capacity sufficient to interrupt the current of the largest motor when stalled together with the sum of the normal running currents of all other motors and other loads. The calculated breaking capacity may be reduced by the use of a proven diversity factor. Where motor(s) are supplied by converter(s) or similar devices, the calculation should take into account the possible effect on the required breaking capacity.
The term "diversity factor" is not defined in this document. I have some idea of what they mean, but it would be nice to get a definition, and a method for determining a "proven diversity factor".
5.3.3 Requirements
