tryinghard
- California
Were are Divisions defined in Chapter 5?
500.5.....
You are now wandering over to Section 500.8 which sets up the basic philosophy that equipment must be suitable for a location?s Class, Division, Group and Temperature Classification. Note the entire new Subsection 500.8(A) on ?Suitability.?Okay I see this. I also notice when purchasing condulets as example the are C1 group C and such. They don't referance divisions, I know the groups matter but when purchasing C1 group C for example I assume its good for gasoline areas?
They aren?t required to reference Divisions. See 500.8(B)(2) and 500.8(C)(2).... They don't referance divisions?
Theoretically, NO; since gasoline is a Group D material and the equipment should be so marked. See 500.8(C)(3). However, since the 1999 NEC, Groups were redefined and non-arcing, sparking or heat producing equipment marked for Group C should be suitable for Group D and is most likely marked that way.? when purchasing C1 group C for example I assume its good for gasoline areas?
