kwired
Electron manager
- NE Nebraska
- EC
My mother in law bought a new house a few years ago from one of the locals that likes to flip houses.
I finally got around to fixing a problem last weekend I have known about for a while, have fixed a few others, who knows what else will someday be discovered.
This is how it was found in a attic crawlspace.
Note the thin yellow wire that doesn't land in the handybox splice box - if you find you are one conductor short in your three way switches just run yellow THHN/THWN that matches the 12-2 NM cable to get the extra conductor. Thing was if this guy knew how to wire a three way switch he already had more conductors then needed in the switch boxes - or at least one of them:
If you can't fit all the cables into the switch box it is apparently acceptable to just junction them in the hollow wall space behind the switch:roll:
More understandable thing uncovered was a receptacle she said she couldn't use - found it was a back wire connection - but the good pressure plate terminals not the stab ins - but he must have completely forgot to tighten one of the terminals as it took several turns before it was tight and worked after that.
From the past - there is a hydromassage tub - no access to the pump at all. my guess is no GFCI, for now there is a GFCI in the basement below that I added into the supply cable - at least the tub has GFCI protection. But am dreading the day when that pump fails and I am the one that is supposed to try to fix it.
This is just a rant about his electrical work, if this were a general construction, plumbing or HVAC forum there is plenty to talk about in those areas as well.
