DIY'ers
RUWired
Pa.
I had to use the mens room at a local hydralic pump repair shop the other day. While i was in there i was looking around as usual, and to the right of the toilet i noticed there was a cutler hammer panel.Wow a panel in the mens room. Out the bottom of this panel was a 2" white pvc plumbers pipe.When the pipe hit the bottom of the wall it took a back to back 90 turn to the inside corner using plumbers street ell's.From there it went through the floor or back wall behind the toilet.I can only imagine what was going on inside the panel box.The panel was close enough you could stand or sit on the toilet while working on it.Next trip down, i'll take a picture of it.
Rick
Next trip down take a screwdriver with you, sit on the throne and take off the cover. Let us know what's going on inside (the panel I mean).
It wouldn't be that first time I've seen plumbing el's used on electrical PVC.
