This always brings up the question as to how you define the NEC ampacity. DLO sizes do not match NEC sizes.
DLO is just a tradename of companies like AmeriCable. If the installation is under the guidelines of the NEC then you would need to use in compliance with RHH and RHW-2 and associated ampacity ratings. If used outside the scope of the NEC then supplied tables may be applicable to the standing being used for the application.
Listen to my LIVE Radio Show- Mondays & Wednesdays -9PM-10PM EST on The Electrical Guru Website
So what is the NEC ampacity of 535 RHW?
All of the DLO I've ever used is marked with an alternate size & type, i.e. 636 DLO / 600MCM RW90. Based on my experiences, 535 DLO would be equal to a 500MCM 90C conductor. (Sorry about the MCM and degrees in C, I'm a Canadian)
I've also had good experiences using Shoo-Pins (http://www.greaves-usa.com/pdf/Shoo-Pin Color Sheet.pdf) to adapt the DLO to regular set screw connectors. I find the adapters with stranded pins work better than the solid pin adapters.
Whose tool do you use to install it? I see a die index, but no other info.
