Do fan coil units ( FCU ) typically need separate motor starters?
Dark Sparky
USA
Electrical Engineer
Do fan coil units (FCU) typically need a separate (non-integral) motor starter? Or - does one typically run power direct from a breaker, and the FCU includes its own motor starter (if required)?
Thanks!
Thanks!
Thanks!
Thank you both for the input! It's not yet clear if the FCU being provided has a starter, but appears that they usually are integral from what you've both said.
