I would suggest that grounding a fibre sheath at all is a questionably bad idea, and grounding it at both ends is a terrible idea.
The OP states he's using single mode fibre, which typically goes long distances (up to 20KM), which in electrical terms could mean between services, and thus you are placing a path between different ground points. Given that the foil sheath is conductive, but quite weedy, the current flow could cause heating or even failure of said sheath. If the PoCo MGN is shoddy, or the distance is long, then you could have a lot of volts between the two ground points and have that reflected across the fibre. That of course then creates a hazard for the installer.
Additionally, we IT folk assume that fibre is true isolation, and we dont want a lightning strike from building A being propogated into building B along the fibre.
