on the one line The conduit labeled 1 between the disconnect and the meter packs do I need to install an equipment ground? the feeders coming into 'M2" are 120/208 3 phase 4 wire feed from utility transformer. the two sets of meters packs are in the same room just 10' away. And if i am required to do i remove the main bonding jumper in the meter packs. or do i consider the disconnect and the meter packs as one item and only pull the three hots and grounded conductor. then run a system bonding jumper between the meter packs and the disconnect M2? thanks for your help
