I am installing a fused disconnect downstream of a distribution panel breaker. The fused disconnect will be used to provide local disconnecting means for a "power buggy" type device of which will essentially be a portable load center. The "power buggy" will be connected to the disconnect during times of operation when additional temporary power is needed.
The OCPD in the panel is a 250 ampere breaker. My question is, do I need to derate the fuse's in the disconnect down to 200 amperes (125% of OCPD) or can I use 250 ampere fuses. The "power buggy" will have breakers for each available load position just like a distribution panel would. I have looked through the NEC, but cannot locate an article giving me good information regarding this type situation.
My other choice would be to use a non-fused disconnect.
Thanks in advance for the help.
