Do LED lights degrade over time
102 Inspector
N/E Indiana
Inspector- All facets
Does the lumen output of an LED bulb degrade over time. It appears that bulbs that were installed 2 years ago do not have the light output that I remember when installed. Since these are in corridors and stairway, my concern is adequate light levels for code compliance. Will obtain light meter to check, but wondered about bulbs getting "dimmer" over time.
winnie
Springfield, MA, USA
Electric motor research
Yes, in particular high temperatures cause LEDs to decay, and one way that manufacturers save money is to use fewer LEDs, driven harder to produce a given light output. This makes the LEDs hotter and causes them to decay faster.
There are other degradation mechanisms; these are seen with many phosphor based lights (LED, fluorescent, etc)
-Jon
ramsy
Roger Ruhle dba NoFixNoPay
LA basin, CA
Service Electrician 2020 NEC
As determined under the LM-80 standard, Manufactures are not required to list LED Lumen Maintenance on the nameplate.
mike_kilroy
United States
Yes they have a useful Life of only 50,000 hours. keep your receipt. I have a couple floods bought 10 yrs ago with same output.
Sent from my SM-G900V using Tapatalk
GoldDigger
Placerville, CA, USA
Retired PV System Designer
About seven years ago I bought some low watt bulbs (upper end of night light brightness) and some floods from the same manufacturer at Costco.
After about three months of constant use the small bulbs were getting seriously dimmer. Costco ended up recalling both types. :(
Fulthrotl
~Autocorrect is My Worst Enema.~
yeah, they burn down, not out.
some luminaries are able to compensate for this.
the fixture is underdriven to start, and as it ages,
there is capacity for it to increase power to the led's
to maintain the same light output over its rated life.
don't expect this on any lower end LED luminare.
this also means, if you think about it, that the device
becomes less efficient over time. sort of like a prius.
as the batteries lose their spunk, the engine runs more
and more in the course of operation.
Yeah, structural design process, power adapter and lamp mismatch, bad heat dissipation ,heat dissipation of lamps and lanterns themselves, transmittance of glass or covers and so on, all these factors will influence the lumen output of an LED bulb.
