An indoor, permanently installed swimming pool has deck trench drains around the perimeter of the pool. The drain grate is stainless steel and sits in a completely fiberglass trench. Each grate is 4' long. Does this removeable grate need to be bonded? Yes, the trench drain is within 5' horizontally of the edge of the pool.
By my code interpetation, I believe it does need to be bonded. The contractor is questioning if it does need to be bonded and wants if required, how to accomplish it.
The only way I see possible is the have the bonding conductor laying in the fiberglass trench and at each grate (there are many), attach a short conductor to the grate from the bonding conductor to allow removal of the grate.
Has anyone run into this before?
Thanks.:-?
Thanks.:-?
