powerpower
- Alexandria, Virginia, USA
Hello World!
Hoping someone can provide clarifications on whether I need to bond and ground a "desktop" style step-down isolation transformer. Here's the transformer I'm interested in using to provide 120V to equipment when traveling overseas at 240V locations: http://www.hammondmfg.com/289T.htm
NEC seems to require bonding and grounding of secondary for transformers rated >1kVA. If I have the 1.5kVA model from the aforementioned transformer series, am I then required to bond my output neutral to ground, and also run a separately derived ground to the same bonding point?
Thanks.
Thanks.
