mtnelectrical
- Essex, New Jersey
Today I got a call from a customer that has a small bakery shop. I wired all the fire suppresion system (exhaust range hood,make up fan, lights, etc) There is a cable that in case of a fire actuates the chemical, close the gas valve for range or oven and actuates the limit switches for the exhaust fan to work. The problem is that a steel cable that goes from the actuator box to the gas valve is broken (1/16" or so). Range hood installers went today to replace it but they found a sparkling situation. When they were about to replace the cable the saw a spark from the steel cable touching the raceway that contains this cable and they told the customer to call the electrician. When I got there start checking everything all my grounds are tight, cables looked good and found 7 volts from gas pipe to my grounded box. When I measured hot wire to ground 127volts and hot to gas pipe 123volts. I couldn't go to the basement (where the mains are)to check building ground. Tomorrow they will get the keys but how this pipe is getting this voltage to ground? Any ideas?
