Re: Do you see any additional violation(s)?
I'm noticing the connector appears to be a rain-tight connector.
If this box is in a damp, moist, or wet place it should be in a Bell box; on a GFCI circuit; with a raintight cover that remains raintight when a device is plugged into it; and properly grounded. These assumptions are based on the minimal data that was provided. Your mileage may vary depending on local codes and circumstances.
210.8A3, 314.4, 314.15A, 406.8B1,2
I'm totally guessing. Do I win? Additionally, I don't know the code section but the device should be attached to the cover with more than just the middle screw. There should be two through-bolts to attach the device to the cover.
[Putting on my X-ray glasses: The EMT should be supported withing 3' of the box, but the picture is too small. The wire nuts might be the wrong size. The conductors are all undersized. It's dirty
../Wayne
PS: It's probably an 8/32" screw also.
[ September 05, 2003, 10:03 PM: Message edited by: awwt ]
